Iris Nebula
One last mirror question for the old guys!
Started by rhinson11, 03/23/2004 04:39PM
Posted 03/23/2004 04:39PM Opening Post
Just out of curiosity, I'd like to get an idea on the age of the mirror I'm going to send out. Or at least how old the coatings are and what type of glass it is. I promise I won't bug you guys anymore after this. O.K. on the back of the mirror is a pink sticker that reads "Hard BERAL Coating, information on dusting and cleaning with absorbant cotton or Mir-O-Clean, and then P.A. Clausing with the same address as now H.L. Clausing. When did the name change from P.L. to H.L Clausing? The mirror was made by an Orris E. Thompson. As for the glass, it's about
1 1/2 " thick, has no color to it, very clear, the back side is not ground, but is smooth and flat with no ripples in it and it hs a fine pebbled surface. If you look at the edge chips with a magnifing glass, they have a clam shell apearance to them. Not jagged or sharp, but rippled, like the outside of a clam shell. Sound like plate glass? I know it's not much to go on, but any thoughts or ideas would be helpfull
Thanks
Roger
Posted 03/23/2004 05:37PM #1
The pebbled surface sounds like pyrex. Beryllium coating has been advertised in S&T for many years. The mirror could be 20 or 30+ years old.
Before I spend a lot of money on it, I would give it a foucalt test, or a star test as Suiter spells out in his book.
Just another shot in the dark. (I do a lot of that with scopes, since 1958.)
Posted 03/24/2004 03:15AM #2
Roger,
If you look at my thread further down about the "Latest From the Workshop", the scope that I am working on actually was made by the same guy Orris E. Thompson that made your mirror. The ones (5" F/9.5, 5" f/4) were ground by him and both have the P.A. Clausing stickers on the back as well. The scope that I'm restoring right now is the 5" F/4 and the mirror is marked "52" on the back. A sticker attached to the side of the scope when I got it said that it was over 50 years old, so I'm thinking the "52" may mean 1952...
Eric
