Pie in the Sky in your Eye
Started by yahganlang, 02/23/2006 04:37PM
Posted 02/23/2006 04:37PM Opening Post
Alright, this one is totally looney-tunes- laugh yourself to death for all I care.
Anyone know whether there is any work showing that photons can hop intervening matter (rather than just fermions)? ATM relevance? Getting past exit pupil restrictions.
If one could 'trick' light into reassembling, as it were, inside your eye rather than having to bother with your pupil, one might be able to get a more camera-quality view. Of course things being the way they are you're probably more than likely to get a lethal dose of hard radiation while you're at it, or inadvertantly open up a wormhole onto another warlike civiliazation or some such.
Anyway, does anyone know of anything remotely resembling what I'm suggesting here? Thanks again to my loyal fan base.
Jess Tauber
Posted 02/24/2006 05:56PM #1
Certainly photons can tunnel. Simple experiment: take two diagonal prisms, remove them from their holders. Place them base-to-base with a small air gap between them. If the air gap is large enough, the prisms will act "normally" demonstrating total internal reflection. As the air gap shrinks, some of the photons tunnel across to the other prism. Of course, when the air gap is reduced to zero, all of the photons pass into the other prism.
Of course, there is a classical physics explanation for this effect, involving evanescent waves, but the quantum-mechanical explanation (tunneling) works as well.
Even if you could get photons to tunnel through the iris, I wonder if a larger pupil would help? Sure, the image would be brighter, but you'd be using the edges of the cornea and lens, making their optical defects more noticable.
Instead, you might (more sci-fi here) direct the photons to the exactly correct spot on the retina. But the eye moves in deliberate patterns to build a complete image. So, you'd have to understand the visual perception process (including the brain's role) in detail.
Now that you understand the brain, you could just excite the correct nerve cells and dispense with the eye altogether! The image would be as bright, sharp and clear as you could imagine.
Thanks for the opportunity to speculate.
Allen
