Speaking of questioning everything
( http://www.astromart.com/forums/viewpost.asp?forum_post_id=294641 )
I am about to cutaway my bottom corner, a la K-B page 192 (diagram p.191). If you don't have your bible in front of you, I'll paraphrase: they say to scribe an arc centered on the center top edge of the side panel (ie. what is assumed to be the center point of the pivot) starting at the bottom edge where the tailgate ends and up until it hits the edge that would join the front of the box.
I'm sure you follow me. Half the boxes I see out there are just 45° cuts, but KB say a curve looks nicer (and I'm inclined to agree). But looks aside, the arc I scribed struck me as quite shallow. Though geomtrically correct (it would minimally clear the rocker box when rotated about that pivot point). I realized that a LOT more material (and hence weight when using BB Ply) would be removed by that plain 45° cut.
For that matter, my questioning continued: why not 60°. Or more?
I am not bottom heavy or anything, it's just a thought experiment that happened when I wondered about how little this arc was and should I just do a 45 instead?
Should I? Pros? Cons? Set me straight*!!!
*or curved
TomL
PS maybe the choice would come down to not just weight removal (if that's at issue) but also how you would cover that hole afterwards. 1/8" thin ply for a 45, but what about a curved cut? Veneer? Open?
*or curved
TomL
