VDB 142 Elephant Trunk HOO
Rebuilding my dob base-HELP!
Started by Jud, 12/06/2007 04:57PM
Posted 12/06/2007 04:57PM | Edited 12/06/2007 05:00PM Opening Post
It is time to rebuild my dob base (12" steel tube 14"OD) and I am seeking Ideas to incorporate the following: Thousand Oaks Controller, battery pack, wiring (neatly), Dip meter (alt angle indicator). Also, there have been posts on stabilizing the mount, plus recommendations for teflon/ebony star surfaces, etc. Of interest would be items like installing tracking components, location of bubble level, a lock to temporarily freeze the az rotation, increasing the size of the trunions, and other recommendations. See attached photo for above mentioned equipment. All suggestions will be welcome.
Jud's attachment for post 39957
I Yam What I Yam!
Posted 12/06/2007 06:25PM #1
Judson:
Were you planning on a climate conditioning system too??? smile
Make it sturdy, kept the bottom board, use a laminated pine 1 1/16inch disk for the bottom board and make the sides stiff. Maybe get Richard Beesely or Dobstuff to cut you some nice altitude bearings...
Posted 12/06/2007 10:50PM | Edited 12/06/2007 10:55PM #2
Hi Judson,
I plan to incorporate my dew control and wiring into a box that rides on the front end of my rocker box similar to this made by Doug Scobel:
http://www.astromart.com/forums/viewpost.asp?forum_post_id=512467
I don't remember if you observe from home or if you ever take it to dark skies, but if weight isn't a problem I suggest two layers of 3/4" plywood for the bottom of the rocker and place the sides on this base. Before I'm flamed for overkill the extra weight is definitely worth it for the increased stability of the mount.
My truss scope is easy to wheel up into my Chrysler mini van and is rock solid for observing. I get no flex or backlash at all and using an Argo Navis with just a casual alignment I can put objects into a 100X EP almost 100% of the time. I (over)built mine using the Kriege and Berry book and used 1" sides for the bearings and 1/2" for the front and back and I'm glad I did. Maybe someday I'll rebuild it into a ultra light.
Oh course, yours is for a tube newt and the rocker has to be tall for your altitude bearings, so you could use 3/4" plywood and use side braces like Floyd Blue has done and posted to stiffen up the rocker sides. I'd still use the double thickness for the bottom.
Keep us informed with how your project is coming along.
Why not go all the way and rebuild it into a truss? grin I leave it assembled in the garage and roll it out to the patio for observing.
jimmoscheck's attachment for post 118828
