RICHARD COFER
Refractor "light-gathering" question
Started by JeffinMd, 12/15/2004 09:52PM
Posted 12/15/2004 09:52PM Opening Post
Do two refractors of the same fL/Diam. ratio have the same light gathering ability in terms of imaging?
I'm trying to learn here, not start an argument.
Thanks.
Posted 12/15/2004 10:40PM #1
Light gathering in terms of point sources (stars, for example) will be the same. For extended objects, the f# is just like on a camera - the lower the number, the faster you can record the object - a 4-inch f/6 will record and extended object 4x faster than will a 4-inch f/12 (but the f/12 will have a larger image scale - the object will, at the image plane, occupy 4x more area in the f/12 system). I suppose this is another way of saying that a 4-inch gathers as much light as another 4-inch.
Posted 12/15/2004 11:45PM #2
What you call fL/Diam. ratio is called the F ratio or focal ratio, as in F 10 or F 4.5.
Light gathering ability is dependent on aperture alone. (Diameter of the primary).
However, as another A-marter has described, on extended objects, a faster (lower number) F ratio will expose a given piece of film or ccd sensor quicker.
