Hi Gang.
Going by the KB book, I and many others feel the recomendations though sound are a bit of an overbuild. That's probably a good strategy as many people will need a little safety provided by slightly over built design to cover up sources of error or slop. Fair enough. I don't want to cut corners either but I want a lighter upper cage without compromising the integrity of the cage.
Here's what I've found: Cutting 1" wide rings (17 OD / 15 ID) with 3/4" struts (9" tall) I have found that putting the minimum in without a focuser board in there just yet... for me (3 vane spider) is 3 struts min, but I feel I can twist the cage set up like that (again no focuser board in there yet, but you get the idea). With 5 struts layed out in an even hex pattern (the focuser board to be the virtual 6th strut) it is so stiff (even without the board) that I feel I could stand on it and definitely can't torque it by hand.
So much so that I was thinking of recutting the rings out of my sheet of 1/4" Baltic Birch Ply instead, and going with 5 struts not 3. I'll probably try it anyway, but if someone has a thought about this or better yet, experience, please share with me. My thinking is that the stiffness is coming from the number of rungs, like a ladder, not from the THICKNESS/WEIGHT of the sides of the ladder. The NUMBER of rungs (struts) is what makes for non-twistable stiffness it would seem.
After all, you ultralighters out there are making foamcore rings, so why not my 1/4" BB idea? Not ultralight, but half the weight of my 1.34 pounds worth of 1/2" BB.
Penny for your thoughts.
TomL
TomL
