router bit - wood tubes
Started by opticsguy, 04/20/2007 02:48AM
Posted 04/20/2007 02:48AM Opening Post
Seems to me that there are router bits made to cut profiles into the edges of wood to make up wood tubes. The router bit only cuts one edge leaving a "corner" for the next plank to fit into place. They come in a variety of "sides". I cant find them on anyones website. Any ideas or suggestions for where to locate?
Thanks, Kreig
Posted 04/20/2007 03:02AM #1
Home Depot will have some
Posted 04/20/2007 06:13AM #2
Sounds like you're talking about a bird's mouth joint, Kreig.
You could cut that with a table saw, with a dado blade set at the proper angle.
Or just make two passes with a regular blade.
The angle would have to be pretty accurate to get a good glue joint all the way around.
Here's another method of joinery, where the "angle" isn't so important.
http://www.woodworkforums.com/attachment.php?s=559f721a229860af53c65113920a248b&attachmentid=43672
Linton
Posted 04/22/2007 03:00PM #3
I Think these are the router bits you are talking about.
http://pricecutter.com/product.asp_Q_pn_E_P16-2865_A_cn_E_361
