james carter
North American Nebula NGC7000
Science-fictiony achromat
Started by yahganlang, 04/09/2006 02:11PM
Posted 04/09/2006 02:11PM Opening Post
Ok, so my posts make 'Unusual Telescopes' look positively run of the mill.
How about a lens that can be cyclically moved to 'reflect' (if you'll pardon the obvious cognitive dissonance..) the differing placement of focus for the different colors- and moved FAST. Secondly, a cyclic chemical filter that utilizes a system of redox dyes to run through the same spectrum in synch with the motion of the lens, so that only the light that will come to focus at any one point on the lens movement cycle gets through to the eye.
Make the cycle so fast that the eye can't catch it.
So just for the sake of argument would this then constitute the experiential equivalent of a pure nonchromatic scope? Substitute a cyclically tuneable GRIN and motion is removed as a variable that can go worng (wave to Yul, all).
Jess Tauber
Posted 04/09/2006 02:32PM #1
I say do it. If we did it yesterday, we will travel at the speed of light and go back in time. Today we could now buy nonchromatic scopes for $19.95 plus $8.95 shipping on HSN.
Stu
Posted 04/09/2006 07:39PM #2
Conceptually it would work. Practically speaking, a tunable filter that operates at 60hz in sync with a your grin is going to be expensive to build and suffers from a very low through-put.
To me it seems like a lot of trouble simply to avoid using a mirror. OA Newtonians avoid the CO issue but require slow focal ratios, standard Newtonians do fine...
