I would just like some confirmation. Using Newt 2.5, I came up with 1.52 secondary with a 14" secondary cage id. At first I thought I was going with a 2.14. Would a 1.83 work? It says I will have vignetting at focuser of 75% ray. Not sure what that means. Thanks
Secondary size for 12.5 f/6.4
Started by Grumpy_one, 06/09/2004 04:36PM
Posted 06/09/2004 04:36PM
| Edited 06/09/2004 04:38PM
Opening Post
Posted 06/09/2004 05:08PM
#1
You have set it for a 1.25" focuser. Is that what you are going to use? If so, then you can get away with the 1.52", but this is going to be a narrow-field instrument... It is also going to be tall, so you will be using a ladder. Is this a dedicated planetary scope? If so, that should work.
For a general use scope, I would make it a bit faster (pick an f-ratio that will allow you to observe without a ladder - probably f5.x, depending on your height). I like wide fields, so I would go with the 2.14" secondary for a decent illuminated field (that's still just 17% CO, not bad at all, and you won't see a huge improvement below that). But that's me, not you. The 1.83" secondary would still do okay in a 2" focuser, just a bit of vignetting in the lowest power eyepieces (like the 35 Pan, etc.).
Jarad
Jarad
Funding Member
Sponsors
- BBLABS LLC
- RemoteSkies.net
- CarbonScopeTubes LLC
- SellTelescopes.com
- Desert Sky Astro Products
- Anacortes Telescope
- Matsumoto Company
- FocusKnobs
- Vernonscope
- APM-Telescopes
- astronomy-shoppe
- Astromart Customer Service
- Waite Research
- kwtelescope
- BW
- AstroMart LLC
- OMI OPTICS USA LLC
View all sponsors
