Shamelessly Copied....
Started by web0178230, 08/29/2006 02:48AM
Posted 08/29/2006 02:48AM | Edited 08/29/2006 02:49AM Opening Post
[COLOR="Purple"]....from somewhere on the internet.
Here's the ground board in raw form. Teflon pads and feet obviously go in the solid areas between the cut outs. The cut outs aren't perfectly round but the ground board is not a part usually seen. wink
The board weighed 6 pounds without the cut outs. The three cut outs decreased the weight by a smidgen over two pounds.
Bill[/COLOR]
web0178230's attachment for post 33181
Posted 08/29/2006 03:12AM #1
As long as the feet are centered on the Teflon, then it should be fine. I always worry about a lightened ground board though, they can become a spring board and cause the vibrations to be amplified. You will be able to tell that went it is mounted. Hopefully this will not be a problem. Looks nice though. smile
