Size of Illuminated Circle
Started by D Brown, 05/04/2006 04:50AM
Posted 05/04/2006 04:50AM Opening Post
Hello all
While there are a large number of resources on the net showing how to calculate the correct position of a secondary, I have yet to find one that will calculate, or provide a formula for determining the actual diameter (in inches or mm) of a mirrors 100% illuminated circle at the focal plane. All of the resources I have seen seem to only calculate the illuminated circle in degrees.
Can anyone help?
Cheers
Doug
Posted 05/04/2006 06:02AM #1
The freeware program 'NEWT' will calculate that for you under -view-performance specs.
http://home.att.net/~dale.keller/atm/newtonians/newtsoft/newtsoft.htm
Hope it helps,
Bob
Fujinon 10x70 FMT-SX binocs
Tak FS-78 ƒ/8.1 - 630mm fl.
