james carter
North American Nebula NGC7000
Source of Silicon Monoxide?
Started by petersm, 03/20/2004 05:33PM
Posted 03/20/2004 05:33PM Opening Post
The Minnesota Astronomical Society’s Amateur Telescope Making (ATM) Special Interest Group along with the Eisenhower Observatory Volunteers in Hopkins, Minnesota obtained a surplus 1960's era vacuum coater from a local college.
The coater is large enough to do a 16-inch diameter mirror.
We are reconditioning the coater and adding a second heated source to be able to apply an overcoat.
Does anyone know where we can obtain Silicon Monoxide for the overcoat?
Are there any safety precautions one should take with handling of Silicon Monoxide?
Mark Petersen
Posted 03/21/2004 12:16AM #1
Photox Optical Systems
http://www.photox.co.uk/EvaporationChemicalsAndAccessories/evaporationchemicals.htm
I have not had any experience with this company but it
looks like they have what you are looking for.
Hope this helps
Ed.................
Posted 03/22/2004 06:46PM #2
Mark,
All suppliers of chemicals or chemical compounds are required to provide a Material Safety Data Sheet (MSDS) for any products they handle (true for everything from dial soap to uranium hexafloouride). The MSDS provides data on known and suspected hazards as well as permissible exposure levels and appropriate precautions. My experience has been that these are usually supplied, and often faxed, at no cost.
As usual, there are lots of terms and acronyms involved that a visit to the NIOSH web site can probably help you decode.
Good luck and be careful!
Mark
