Philip Imbrogno
Elephant Trunk Nebula
Speaking of Teflon
Started by richardpeters5, 04/23/2008 01:28AM
Posted 04/23/2008 01:28AM Opening Post
As the subject of Teflon was being discussed earlier, I was curious to know if anyone has ever tried using "UHMW" in place of Teflon for Az/Alt bearings, etc.? It seems to have very much the same properties as Teflon...but it's sooo much cheaper.
Rich
Posted 04/23/2008 04:35AM #1
I tried using UHMW for the thrust bearings in a Schaefer style GEM. The UHMW had too way too much stiction, although lubricating it with Superlube helped a lot. I ended up using HDP instead. It works much better for the application. The reason I didn't use Teflon was that Teflon cold-flows under pressure which eventually messes with the worm gear alignment.
