Specialty Tools for TM'ing, Part I
Started by P. Lee Stock, 03/04/2004 02:45PM
Posted 03/04/2004 02:45PM Opening Post
We had that recent thread on how to position the focal plane relative to your focuser travel, so I thought I'd post this.
I made this tool to help with the problem of determining the ideal primary mirror/cell location in a tube. Most modern newtonian focusers are low profile and have drawtubes with a travel range somewhere between 1-1/4" to 1-5/8" or so, which means you really only have 1/4" or so of room for error when positioning the focal plane relative to the focuser/drawtube travel or many eyepieces out there won't come to focus within the range of your focuser.
When assembling the components of a tube, I first install the focuser and then the secondary mirror assembly. Then, after leaving the tube intentionally long, I insert this into the back, flush with the end. With my trusty TV plossl (I bought one just for this purpose), I take the telescope out under the stars and advance the primary mirror using the extremely long screws until stars come to focus. This tells me exactly where to position the cell.
When I mess up and get the primary too close to the secondary, I get to make a brand new tube since my cells attach to a back plate that attaches to an end ring, Richard Berry style. I hate that. When others get it wrong, they either have to drill new holes for the mirror cell, or new holes for the focuser and spider, or make a riser block for the focuser. Why guess?
The reason for using a TV eyepiece for this function is explained here:
http://astromart.com/messages.asp?message_id=180100&page=
This one is for 10" mirrors. I suppose I could have made one that adjusts for 8", 10" and 12.5", but I went the separate tools method instead. Note that it has very long travel. There are nails set into the wedge blocks that grab the tube wall for peace of mind. I wouldn't trust friction alone.
If you are making just one scope, then this is overkill. But if you are planning to make a few in your life, this is far better than guessing where the focal plane will wind up and being completely wrong, or having your son peek through your Nagler while you sit on the ground with a mirror in one hand and a measuring tape or pencil in the other asking "are they points yet?" That got tired.
Cloudy Skies!! (TM'ing weather)
Lee
P. Lee Stock's attachment for post 13759
Posted 03/04/2004 10:30PM #1
Very nice Lee! Here's a pic of my 14.5" cobbled up to determine truss length. Not very elegant! That's a 1X6 attached to the mirror box with clamps and the cage is attached with velcro straps. I just moved the cage back and forth until I had it in the right place. Then it's just a matter of measuring the seapration between the top of the mirror box and the bottom of the cage. Cut poles to a length that gives that distance and Whala! All EPs come to focus.
Bill in SA
Posted 03/06/2004 04:25AM #2
I have one more tool that I made for my most recent scope. I was very concerned about balancing the final scope. So instead of calculating the the COG I decided to measure it. I built the following jig to try out various positions for the altitude bearings. I use roller blade bearings the altitude bearings rest on. This gives me a lot less friction than the final rocker box design so if I can acheive balance with this jig then I should have no problem with the final design. This theory has yet to be tested as I haven't built the rocker box yet.
Moose408's attachment for post 77165
