Still Another Telescope Project
Started by Barry Simon, 03/09/2005 03:15AM
Posted 03/09/2005 03:15AM Opening Post
About 2 months ago I could not pass up a really good deal on an older black tubed Vixen C102 f/9.8 refractor as made for Celestron in the late 80's. These scopes on a Super Polaris mount sold for about $1200 in the late 80's. The one I bought was about 1/2 that on eBay. The mount is in great shape, but the tube had some cosmetic damage (focuser and objective cell were fine). The damage did mandate repainting, but as replacement decals are no longer available from Celestron, I decided to go in a completely different direction in respect to refinishing this telescope.
The tube damage consisted of some ugly marks from a previous owner going thru the cradle rings and contacting the tube with the bolts. Several other marks down to the bare metal were on the tube side. While slightly dented in a few places, there was no major damage and these marks are barely felt on the inside. Collimation is fine. I decided to repaint. I kept changing my mind over the past few weeks - would it be a nice ivory, or perhaps black again, maybe a nice dark blue (no too "Meade-like"). I finally settled on purple after I saw this new series of paint which is supposed to mimic an anodized finish. It does look anodized if painted on a properly prepared bare surface. However with the tube repair (JB Weld), I had to use the recommended base coat, which is a special metal flake silver. When the paint goes on at the proper thickness it looks like a solid purple enamel, but as it cures the metal flake characteristics come out. It should look spectacular in bright sunlight. I will probably use it mainly as a public education telescope. I am going to call it the "Purple Planet Eater". There is a flat space on top of the focuser where I can mount a little plastic figurine of Marvin the Martian if I can find one. Can anyone help here?
See the photo of the dew shield that I have attached.
I baked the dew shield and the finder tube in the oven (140 degrees for 1 hour) after about 18 hours of air drying. This really speeds the curing process up. All parts are suspended on hooks and no support contacts a painted surface. This stuff does not cure as fast as an automotive lacquer or even some other enamels which are good to go once baked in the oven. The tube is too large to treat in the oven, so I have it where it can catch some direct sunlight. I probably will not feel good about reassembling the scope and mounting it in the tube rings for at least 2 weeks if not longer due to the slow curing process. The oven baking also really brings out the gloss in the paint.
Barry Simon
Barry Simon's attachment for post 22765
Posted 03/09/2005 03:42AM #1
That purple is a great color for a scope! I've done some accessories (tube rings) in purple but never got around to doing a whole scope. Maybe now I will. Can I ask where you got the paint?
Thanks!
Bill in SA
