Hi Gang -
I just purchased a Meade 8" SCT on an LXD500B which is my first real telescope. I was all excited and then of course I was immediately sent on the road and then met with clouds. Ugh. :S
Anyway, the mount was a little sloppy and tight and so I commenced tearing it apart, regreasing and reassembling. The DEC went fine, but while doing the RA, things went horribly horribly awry! When I was putting the worm assembly back on I managed to strip the left little machine screw that connects it to the mount. The other bolt kept it reasonably held on and so I gingerly connected the other. I tightened the other bolt and things were ok. But, when I was then adjusting the center screw to back the worm off a touch and hopefully lighten the action, I stripped it. It is workable now, but obviously the RA is fairly tight to turn and I'm pretty bummed about the whole deal. I'm so ready to move beyond my DS2114ATS and old 60mm refractor and the first thing I do is start stripping threads on my new mount. Lovely.
Now, I know that I probably seem a bit overzealous, but I race bicycles and make adjustments to them and haven't stripped threads before. So, I was being fairly gentle. So, how do I move forward? Do I tap them to the next biggest size? Can I use permatex (??) to repair them? Am I out of luck? Does anybody have a LXD500 head floating around that they'd part with on the promise I leave well enough alone? What is the best way to approach this awful problem?
Anyway, I didn't know where to turn, so hopefully this is the right bunch! Thanks in advance for any help and advice. I've learned my lesson, I just need to figure out how to make it right.
Thanks very much,
Kevin
Thanks very much,
Kevin
