Thanks Floyd!
Started by web0178230, 10/04/2006 03:02AM
Posted 10/04/2006 03:02AM Opening Post
[COLOR="Purple"]I took Floyd's advice and picked up one of the Werner wide tread three step step stools. I wish it was 2" taller at the top step but overall, it should work fine. A plus I hadn't considered is that it folds to less than 3" thick so will take up less room when travelling.
Bill[/COLOR]
web0178230's attachment for post 33798
Posted 10/04/2006 03:05AM #1
[COLOR="Purple"]Here's a pic of the USA (Upper Support Assembly) with the newly crafted baffle. Before the baffle and the heat shrink on the tubes, I was a little back heavy. With the newly added weight, things balance very well!
Bill[/COLOR]
web0178230's attachment for post 107879
Posted 10/04/2006 03:41AM | Edited 10/04/2006 03:42AM #2
Hi Bill,
You just add a 2" piece of hard foam to the top tread for a little extra height. A hard rubber or foam would work great and maybe even be easier on the feet. There are a few materials that are readily available.
I bet the wide treads are nicer huh? I always liked the wide treads and the handle for holding at the top. Plus, you can add an EP holder to the upper tray.
How do you like the curved spyder? I do like mine.
