Tube cutting
Started by tnboy426, 01/10/2006 09:02PM
Posted 01/10/2006 09:02PM Opening Post
I have a dob that I would like to convert to a split-tube. The optical tube is made of sonotube, and I would like to get a nice smooth cut. What would be the best way to do this? Razor blade, a sharp razor knife, dremel, bandsaw, something else? Could someone lend some advice? I would appreciate any advice possible.
Thanks...
Posted 01/13/2006 09:04PM #1
I've had good results simply using a hand crosscut saw, the same kind that you use to cut wood. Make a line around the tube and support it well on both sides of the cut. Then slowly cut around the tube, keeping the saw nearly tangent to the outside of the tube. It's best to work so the end of the cut is coming towards you, just as if you were cutting a sheet of plywood. This results in a very nice smooth, straight cut.
Posted 01/20/2006 08:58PM #2
Hey Michael,
How do you plan to fasten the 2 tube half's together while viewing? Some kind of latches? Like tool box latches maybe??
I am very curious to hear from anyone how this has been done and with what success. Any good ideas??
Paul
