Two Piece Truss Poles - Might Work!
Started by web0178230, 09/18/2005 07:59PM
Posted 09/18/2005 07:59PM Opening Post
[COLOR="Purple"]The tube connectors arrived so I tried them on two of the short tubes that I have that I'm hoping to make into one longer tube that can be broken down into two pieces. Seems to work well! The assembled tubes are over 7' long and when screwed together are very stiff at the joint.
The two pole sections do not line up exactly; offset laterally from each other due to the "slop" in the connectors. When screwed together, the entire tube is straight, just offset a little at the joint.
The hardware adds about 4 ounces to the tube weight, acceptable in relation to the total weight of the long tube, not to mention the convenience of being able to transport the tubes broken apart instead of in a single 7' length.
1st pic is the hardware used to join the poles.
Bill[/COLOR]
web0178230's attachment for post 26904
Posted 09/18/2005 08:01PM | Edited 09/18/2005 08:01PM #1
[COLOR="Purple"]Here's the tube ends with hardware installed.[/COLOR]
web0178230's attachment for post 96165
Posted 09/19/2005 05:08AM #2
By Georgy, I think he's got it!!!! Having used about a thousand of those inserts, I would caution you to be very sure that your tube ends are square. I do this by gently rolling them on the table of my disc sander.
Posted 09/22/2005 07:26AM #3
Good idea you have there. Stiff poles that can also break down for travel are a universal ATM problem.
Lee
