Hi All,
OK, The maker of the mirror tells me that because they put a coating to protect the alumium.They tell me alcohol, acetone, or thinner should be ok, followed by losts of distilled water as long as its clean and no rubbing the mirror.
I tried a small amount of alcohol no change in the silicone or the silicone but I made me a little nervous because it made a green haze and I was afraid it was damageing the coatings.
Then I tried the acetone, it worked a little better the mirror was really shiny but silicone still there.
The last thing I used was a goo remover kind of a citrus based cleaner. I worked much better but did not remove all of it.
I will keep you posted as to results. just in case this happens to any one else.
Sonya
Sonya
