Where to get clock drive parts?
Started by Aircrftr, 01/03/2007 04:42AM
Posted 01/03/2007 04:42AM Opening Post
Hi all;
I'm thinking of making a larger RA gear for my scope to cut down on PE, I wanted to know if anyone knows of a place I can buy worm gears, variable speed drive systems, etc.
Mucho thanks, Dan
Posted 01/03/2007 05:46AM #1
Dan,
Before you click on the links below please be aware that PE is caused by the worm, not the main gear or its' size.
Here is a source for drive gears and some info.
http://www.opticcraft.com/
Source for worms.
Use left product list, go to gears/worms. Then you can filter your search.
https://sdp-si.com/eStore/
For drive electronics this is the cheapest I have found for the do-it-yourselfer. No computer required in the field. One is needed to program the box for your specific drive gearing. It may be easier to design your drive to work with a used Losmandy G-11 drive system. They come up for sale pretty regularly here in the classifieds. I paid 200 for mine, 2 motors, hand pad, electronics box, and all cables.
http://www.bbastrodesigns.com/BBAstroDesigns.html
Hope it helps,
Bob
Fujinon 10x70 FMT-SX binocs
Tak FS-78 ƒ/8.1 - 630mm fl.
