Wizard Nebula
Wider...or...Thicker? Design Question, Not Spam
Started by web0178230, 08/16/2006 12:19AM
Posted 08/16/2006 12:19AM | Edited 08/16/2006 02:03AM Opening Post
[COLOR="Purple"]No, it's not a "male enhancement" question posted in the wrong Forum. shocked
The minimalist design of my single upper ring has resulted in some flex when I hang a heavy EP in the focuser. Sooo...some beefing up is probably needed. The ring is 3/4" thick plywood and it's 1.13" wide.
My question to this august group is: Do I increase stiffness most by making the ring thicker or wider? I can see both ways working but I have no idea which is the best way to go.
What say ye?
Thanks!
Bill[/COLOR]
web0178230's attachment for post 32968
Posted 08/16/2006 04:40AM #1
I would say thickerer. I don't think making the ring wider say 2" would have a significant effect on flexture. Where doubling it's thickness would stiffen things up quite a bit.
If you think about a piece of ¼" ply, no matter how wide you make the ring you can flex it pretty easily. Now think about a ½" piece, how much harder it is to flex it. Wha-la
The "star" we look at tonight may have exploded millenniums ago. (To progress, we must discern what exists and what does not).
Posted 08/16/2006 04:49AM #2
Doubling the thickness will definitely make it stiffer. I would think the another 1/2" lammenated to the original would be enough to make stop flexing.
Posted 08/16/2006 09:40AM #3
Bill
I would say both. The force of the spider is pushing outward. You would better serve your purpose with more width. More thickness to better support the focuser. Also what kind of plywood wink would make a huge difference. Joe
Posted 08/16/2006 03:53PM #4
How do you see it flexing? Or--How do you know the flex is in the ring and not the spider?
