Celestron Edge HD 1400 Focusing issues
Started by skchawla, 05/23/2013 08:36PM
Posted 05/23/2013 08:36PM Opening Post
I am having focusing issues with my celestron edge hd 1400 it will not focus I took out the screws as the celestron tech support told me to and still no go. I took off the corrector plate to see if the primary moves, the mirror does move but when I put in the eye piece I dont see any change when I try to focus. I can see in the diagonal the image its not blurry but still when I turn the focus knob nothing happens. Can anyone help me out? I am going to ship it back to celestron but they are lagging so I just wanted to know if there is anything else I can try before I send it back.
Thank You
Posted 05/24/2013 04:32PM #1
Hi Siddharth,
You could try adding a long extension to see if the scope is coming to focus behind the current eyepiece location or remove the diagonal and see if the scope is coming to focus in front of the current eyepiece location. There are 2 mirror lock knobs on the back of the OTA but since you’ve already verified the primary mirror is moving, they must be disengaged. Is there an astronomy club in your area where other Edge HD owners might be able to help you?
- Tom
Posted 05/24/2013 05:32PM #2
Thank You
What are you trying to focus on? If the focus is very far off, you wold be surprised how little "change" there is visually until you get somewhat near focus.
Not knowing any details (and assuming I am even understanding the problem you are trying to describe), try and focus on a distant, easy-to-see object, like a hillside a mile away or so, with tree's, buildings, etc. It needs to be a large enough target that you should be able to point the telescope at it without the use of a finder. If necessary, pull the eyepiece out and just look through the visual back to get the item(s) in the field of view.
Then put the eyepiece on and run through a very wide range of focus in both directions until you can start to see convergence in one direction or another. I have been as many as 50 "turns" of the focuser off when setting up a new instrument.
If the focus is very far off, you can turn and turn on a star field without seeing anything.
If the mirror is moving as you stated, it's is probably just way out of focus and nothing "appears" to happen when you turn the focuser.
Posted 05/25/2013 01:41PM #3
1. Make sure the mirror locks are disengaged.
2. Focus on a distant object--like the Moon.
3. Be aware that the primary moves by very small amounts as you focus and that its movement is not very obvious.
wink
Uncle Rod
Time on your hands?
