Re: Meade 10" 2120 quartz LX pulse drive
Started by Skywatcher, 11/07/2011 02:38PM
Posted 11/07/2011 02:38PM Opening Post
Alex, it sounds like it is working like it should. The movements will be very little as it is just for guiding corrections. It will not slew like the newer go-to computerized models. The RA setting circle is marked in 24 one hour increments. Set it on one, turn it on, lock the RA, and come back in one hour. It should have moved to the next hour mark. If so, all is well.
Alex Andreani said:
The drive does not seem 2 work, tiny buzz and little movement when E. & W buttons r pressed.
Is the motor supposed 2 run the entire time the buttons r pressed?
Stupid nubie question # 2,
When I turn on the tracking drive on the motor is also supposed to run right, can u usually hear this drive run.
Can I get parts to fix drive, if so, where do I get them?
