Lee Spain said:
If I were to find a relatively dark spot in central Georgia and dare to get out of my car, can any body suggest a good handheld binocular target? I've got 50mm Celestrons with built in skyglow filters. 8O
Binoculars can be a real joy to use, especially if you have a way of mounting them on a tripod - that effectively doubles what you can see.
There are plenty of binocular object lists online;
BinoSky - best bets for stargazing with binoculars
http://www.lightandmatter.com/binosky/binosky.html
Using Binoculars - Highlights for Beginners:
http://www.fvastro.org/beginners/bino/default.htm
Binocular Astronomy Resource Page
www.uvaa.org/BinocularResources.htm
Binoculars for Astronomy:
http://www.skyandtelescope.com/howto/howtoequipment/3389576.html
I've culled these springtime favorite objects of mine from some of them:
Collinder 70 (Orion's belt area). From
http://www.backyard-astro.com/deepsky/bino/02_b.html
"... a large open cluster, located around the belt of Orion. Collinder 70 includes all three belt stars: Mintaka (the Girdle), Alnilam (The string of Pearls) and Alnitak (the Belt). The cluster has a diameter of almost 3 degrees and consists of 100 stars or more. Most of them are of the 10th magnitude or brighter.
This is an object for binoculars! In a telescope you would only see a part of this magnificent deep sky object. On a clear and moonless night, seeing Collinder 70 with all it’s stars grouped around the three bright belt stars, will give you the same WOW experience as looking at the Pleiades or the Alpha Persei cluster for the first time."
and Melotte 111:
"..the Coma Star Cluster was not visible with the naked eye. After searching for a few moments, I found the star cluster in the area between Leo and Bootes with the 15 x 80 Vixen binoculars. I immediately noticed that the Coma Star Cluster is way too big for the 15 x 80 with its 3.5-degree field of view. I switched to the 7x50. The cluster just fitted into the 6-degree field of view of the Bresser. This cluster is really impressive."
and M44:
" ...This big open cluster lies at the heart of the constellation Cancer, between two stars, Gamma (?) and Delta Cancri (?). It has a diameter of more than 1.5 degrees. It is definitely a binocular object."
You can find monthly lists of binocular objects in PDF format at
and from BINOCULAR OBJECTS Compiled by Karen W. Pierce ;
Andromeda
M31 – The Great Galaxy in Andromeda
The most distant object that can be seen with the naked eye, it is superb in binoculars. This galaxy is our closest neighbor, 2.2 million light years away.
NGC 752 and The Golf Club
Open cluster about 5 degrees from Gamma Andromedae. Because it is such a large object it is easier to see through binoculars than a telescope. There are about 75 stars in this cluster. Look 1 degree west of NGC 752 for a small pattern of 7 sixth and seventh magnitude stars in the shape of a golf club. NCC 752 reminds some as a golf ball next to the head of the club.
Auriga
M 36
Bright open cluster contains about 60 stars of 8th magnitude or fainter. Collectively they shine at 5th magnitude and lie 4,100 light years distant.
M37
An open star cluster about the size of the moon, it is one of the finest in the northern sky. It has at least one red giant near the center, giving the appearance of a "ruby in a field of diamonds." M37 lies about 4,600 light-years away. Binoculars will show this cluster as a misty spot. In a 6-inch telescope more than 100 stars can be seen.
M38
This small, open cluster of stars resembles an "X" when seen in wide field eyepieces. It contains about 100 stars and is about 4,200 light years away.
The Minnow
Another binocular highlight is an asterism sometimes called the Leaping minnow; a little group of 5th and 6th magnitude stars. Have you seen this cluster?
M 67
This 6th magnitude open cluster has 500 faint stars spread over ½ degree. Can be found with binoculars but easier with a small telescope. It is about 2,500 light years away.
R Cancri
A bright long-period variable; At its maximum it is magnitude 6.2. It varies down to 11.2 and back in a year.
Canes Venatici
M3
A rare gem in the northern sky, this globular cluster is some 35,000 light years away and 200 light years across. It contains perhaps 500,000 stars.
Canis Major
M41
A beautiful open cluster of about 80 stars surrounded by a rich field of background stars. This is perhaps the dimmest object visible without optical aid. Aristotle noted this object in 325 B.C. as one of the mysterious "cloudy spots" in the sky. This cluster is about 2,200 light years away.
NGC 2362
This open cluster is often overlooked but is a beautiful sight. At magnitude 4.1 it is easy to find, and is 4,600 light years away from earth.
The Boomerang
Look about 1 degree from Delta Canis Majoris for a half circle of 7 stars of 4th to 6th magnitude. It resembles a boomerang. The brightest star near the bend is Omega Canis Majoris.
Collinder 140
This bright, large open cluster is near the tip of the dog's tail. Some 30 stars of magnitude 5 to 9 are gathered here. The main ones form a narrow pattern reminiscent of the famous “Coat Hanger” asterism found in Vulpecula.
Cassiopeia
Owl Cluster - NGC 457
This is a very interesting object to see. In a small telescope some people see an Owl perched on a limb while others see E.T. This cluster is believed to be about 9,300 light years away and contains several thousands of stars.
M52
This open star cluster is large and rich, containing about 200 stars. It is magnitude 6.9 and lies 7,000 light years away.
Coma Berenices
The constellation itself has no bright stars and is hard to distinguish, but it is a remarkable area of sky and is beautiful in binoculars. One of the finest open star clusters for binoculars.
M53
This fine globular cluster is about 3 arc minutes in diameter and is located close to A!pha Comae Berenices. Similar to M13, this cluster is about 60,000 light years away and is about 8th magnitude.
Corona Borealis
Another fine binocular constellation comprised of a small semi-circle of faint stars, very distinct. It is interesting to see how rnany stars can be seen within the “Crown”. 7 x 50 binoculars reveal at least 15 stars.
Gemini
M35
This bright 5th magnitude open cluster is visible with the naked eye, is beautiful through binoculars and spectacular in a small telescope. It contains about 300 stars and is about 2,800 light years away.
Monoceros
M50
This beautiful open cluster is easy to find being 6th magnitude but is not as spectacular as others. Some of the 80 stars in this cluster are arranged in pretty arcs. This may be seen naked eye on the best of nights.
NGC 2244 and NGC 2237
Ten degrees east-southeast from Orion’s giant Betelgeuse, a narrow rectangle formed by three nearly parallel pairs of stars should be visible. These stars belong to NCC 2244, a bright but sparse open cluster that stands out nicely in any binocular. The faint haze encircling NGC 2244 is the famous Rosette Nebula, NGC 2237. Binoculars are ideal for glimpsing the low-surface-brightness of the Rosette.
The Great Nebula - M42
Plainly visible to the naked eye it can clearly be seen in binoculars in the city. M42 lies about 1,600 light years away and is over 30 light years in diameter.
M43
This is a small patch of nebulosity just north of the Orion Nebula. In fact, the M42 complex is the brightest part of a gas cloud covering the constellation of Orion at a distance of some 1,500 light years.
Perseus
M34
This bright, 5th magnitude open cluster sits in the middle of a rich field of stars. It is an interesting view through binoculars or a telescope. It contains about 80 stars and lies about 1,500 light years away.
Double cluster - NGC 869 and 884
Two of the finest examples of open clusters in the sky, are magnificent through binoculars or the low power field in a small telescope. They are at a distance of about 7,400 light years away. Beside the double cluster there are 6 other clusters that are visible in binoculars. Have you spotted them yet?
Taurus
The Pleiades - M45
Also known as The Seven Sisters, it is the most famous star clusters in the sky. On a reasonably dark night you should be able to see at least six of the stars in the Pleiades with the naked eye. Containing more than 500 stars in all, the Pleiades is about 410 light years away and covers an area four times the size of a full moon. It is best seen with binoculars.
The Hyades
Like the Pleiades, this is also an open cluster, but it is so close to us (only about 150 light years away), even when viewed with the naked eye the stars seem to be spread out. Lots of color can be seen as the individual stars are studied. Can you pick the differences out? Try enhancing the colors by slightly defocusing your binoculars.
Ursa Major
Dubhe
This bright, 1.8 magnitude star has been named as Utah's centennial star being 100 light years away.
Mizar and Alcor – “Horse and Rider”
This famous apparent double star in the middle of the dipper's handle is separated by 12 arc minutes and is possible to be seen as a pair with the naked eye. Mizar is itself a true binary star separated by 14 arc seconds.
I would also add:
Alpha Persei Association. From
http://www.lightandmatter.com/binosky/aper.html ;
" ...This is a much more impressive sight through binoculars than the more famous Double Cluster. Bright and big, this is one of those things that only binoculars are well suited for viewing."
More from http://www.lightandmatter.com/binosky/binosky.html about M47, an open cluster in Puppis;
" ...An enjoyable view even from light-polluted areas, provided that it is high enough above the horizon. The cluster is bracketed by two bright stars, of magnitudes 5.6 and 6.4. Cutting diagonally through the center is a chain of four 7th and 8th magnitude stars; the innermost two of these actually consist of a magnitude 7.9 star on top plus an unresolved pair of magnitude 7.9 stars under it. The two 5th magnitude stars are not part of the cluster."
Binocular Astronomy books of note:
Binocular Astronomy by Craig Crossen and Wil Tirion
A great general book on astronomy - covers the astronomy, mythology and binocular targets of the night sky in a very well written manner - I find it a real joy to read.
Touring the Universe through Binoculars by Phillip Harrington
A very large catalog of everything worth looking at in binoculars in the night sky for most of us - almost overwhelming in its thoroughness.
Binocular Highlights by Gary Seronik
A recent but well done addition to binocular astronomy targets - not nearly as detailed and comprehensive as Harrington's book, but will give you plenty of maps and objects to start with.
