>>>I have a fairly basic second hand 150mm reflector (900mm FL, EQ2 mounted), and the standard 4mm eyepiece supplied can barely make out the bands on Jupiter.
Jeff:
Right now Jupiter is quite close to the horizon even at Sunset so it is unlikely that you will be able to get nice views. You are looking through a lot of atmosphere and it is quite rare that the atmosphere will be stable enough to provide steady images.
As others have said, increasing the magnification will not help. In fact reducing the magnification to something around 100x will probably show you more.
There are several factors in getting good views...
- Decent optical quality and collimation. The mirrors need to be properly aligned so that eyepiece is centered on the mirror. There is a bit of a learning curve here.
- A thermally stable scope. When you take a reflector outside, the telescope is warm and creates "mini-mirages" inside the telescope itself. It will take 30 minutes to an hour or more for the scope to provide its best images.
- Good seeing conditions. The light columm coming to your scope through the atmosphere from an object is 6 inches in diameter and 50 miles or more long. If the atmosphere the atmosphere needs to be stable or you will not get maximum resolution. Obviously the seeing is an act of nature and you can only wait for the nights when it is good.
But there are somethings you can do to reduce the effects seeing, there are local effects.
- Avoid viewing directly over houses, trees, buildings, these give off heat and disturb you viewing.
- Try to observe on grass rather than pavement. Pavement, concrete in particular, stores heat and at night gives it back again disturbing your views.
- Pay attention to the altitude of the target, how high above the horizon is it?? Objects that are low on the horizon are not going to be clear and sharp. UNfortunately Jupiter is low and setting in the early evening so there is not much one can do here.
Questions:
What scope do you have?? I am not aware of a 150mm (6 inch) reflector with a 900mm focal length. I know of several 114mm (4.5 inch)Newtonians that with a 900mm focal length, these are quite standard and under good conditions should show good views. The tube size is normally about an inch larger than the mirror.
What eyepieces do you have? While high magnifications sound attractive, most viewing is done at lower magnifications even with larger scopes. As you increase the magnification the image size increases but the brightness decreases drastically, the contrast and sharpness also decrease.
So the trick is finding the best magnification for a given object on a given evening. Sometimes 200x will be easy, some nights 125x will be impossible...
This means having a several eyepieces to pick from is almost a necessity.
What size (0.965in or 1.25 inch) and type are your eyepieces? (H, SR, Kellner, Plossl?) Often the eyepieces that come with a telescope are quite poor and upgrading to good quality eyepieces, ie Plossls, will transform your views, sharper and clearer with a wider field of view.
Bottom line: Jupiter is fading fast in the evening sky, it has been a month or more since I have had a decent view of jupiter even though I look at it nearly every evening.
Right now, the interesting planets, Jupiter, Saturn and Mars, are gone for year so it is time to turn you scope towards the deep sky.
