Ghost of Cassiopeia
Craftsman Mechanics Seat for Telescope Viewing?
Started by ps, 02/26/2008 09:20PM
Posted 02/26/2008 09:20PM Opening Post
Has anyone used Sears’ Craftsman Mechanics Seat for telescope viewing (see attached photo). It can be adjusted from 14.5” to 19.5” and was selling for $22.00. However, compared to Televue’s Air Chair, it’s much shorter (Air Chair can be adjusted from 21” to 28”). I have a 10” LX200. Any comments and / or suggestions will be greatly appreciated. Thanks in advance, Paul smile
ps's attachment for post 41054
Meade 10" LX200
C9.25 ASGT
Orion 10" XTi
Orion 80mm ST
Posted 02/27/2008 02:34AM #1
I tried a similar one last week. I was a little sceptical at first, but it works fine. Soft ground + big behind.
Not for tall telescopes.
Very economical.
Regards
John
Posted 02/27/2008 12:02PM #2
Paul:
This is my two cents...
Of all the various accessories one can buy, the single most important one is an observing chair. It's the one you will use with just about every telescope you ever own, just about every night night, and you will be using it 100% of the time you are looking through the eyepiece. You will be using more than another other.
A good observing chair means you will be as comfortable as possible for the entire session. A chair that takes time to adjust or isn't tall enough or low enough or is unstable gets in the way of enjoying the view.
This chair might work for a while with some mods, but in general it's too low and will not be stable on a soft surface. With your 10 inch DOB, you will need a taller chair for sure.
jon
