RICHARD COFER
EP case advise needed
Started by ghacker, 12/13/2006 09:15AM
Posted 12/13/2006 09:15AM | Edited 12/13/2006 09:48AM Opening Post
I can't believe I couldn't find any advise on this subject on the forums. Maybe I'm just not using the right keywords. I thought this is a great topic for the beginners forum so here I am.
If you discount the cardboard box I've been using, I want to build my first EP case. Rather than experiment and "reinvent the wheel", I thought I ask for advise from forum members who have, collectively, made hundreds, if not thousands, of these.
My strategy so far is this. I've got 2 scopes, a 6" SCT and a 10" XTi and each has a small case for the accessories (finder, batteries, controllers, etc.) specific to each. I want to have one case that holds all my EPs.I know eventually that I could outgrow one case, but I to keep as many EPs as possible in one case to minimize all the stuff I lug around. I've acquired 11 EPs so far with 2 barlows-mostly Naglers, Pans, and Hyperions with a few orthos and plossls thrown in for good measure. The 35mm Pan is the largest.
I've got a large Doskocil case with interior dimensions of 18 3/4 x 14 x 8 with the charcoal "pluck" foam. This should allow me to store everything vertically. I think I can figure out the best layout, keeping the high mass EPs in the middle. But I'd like advise as to the mechanics of making the cutouts.
Do you think I should I stick with the charcoal, low density foam, or get the higher density polyethylene foam. What's the best way to cut the foam? Do you undersize the width of the cutouts for a tight fit? What do feel is the minimum distance between cutouts (I'm thinking about 1"). Any other things I should consider?
I get the impression that most store EPs with caps on. What about no caps but in a bolt case? This appeals to me since you could keep the most frequently used on a given night in a fanny pack without worrying about damage from banging around. And offer dew protection if on a rack.
All opinions are appreciated. Thanks in advance.
Dennis
Posted 12/13/2006 01:37PM #1
Dennis: This task is far too difficult for the average person, it takes someone skilled in the art of placing eyepieces in a box.
Fortunately I have a degree in this very subject so if you send me your case and eyepieces I will be happy to give an estimate on what a full installation would cost.
grin
On a more serious side. I think the best way to go is the foam that comes is already cubed so it is easily shaped.
Some other thoughts:
I store my "main" eyepieces in such a case with caps on them. I have a "main eyepiece case" which contains my first line of eyepieces, a laser collimator, a Paracorr, a couple of barlows, a cheshire, and a tool or two. When I am going to a dark site, I know that if I have this case and a telescope, I haven't forgotten anything.
The rest of my eyepiece collection I store capped or in their plastic cases in boxes in a drawer. One of these days I will build a second case for the orthos and plossls and maybe a third for more classic eyepieces but right now one is enough work keeping organized.
Posted 12/13/2006 04:49PM #2
Hello Dennis,I have an aluminum pistol case from Walmart with the pluck foam that is the size of a leather briefcase.You could put everything you have in it and still have lots of room for expanding your collection.This case is $29.95 .Cheers,Darrell
