First night out with my 130ST!
Started by JesterDev, 07/08/2006 06:33AM
Posted 07/08/2006 06:33AM Opening Post
It came in last night and after waiting for a thunderstorm to pass the sky was clear as can be. However the moister was a bit much and made viewing a bit blurry. My first target was the moon which looked simply amazing and more detailed then I remember from some 26 years ago. After spending a few minutes there I moved a little more to the southwest to see Jupiter. While the views there where not all that amazing since the moon was already winning the light battle, I was still quite impressed. Other then that I just combed the night sky's for interesting stars to look at will morning came so I could take my first peek at Venus. I was unable to see anything interesting (not that I really know how to look yet) other then some stars I've been staring at for many years. At about 4am Venus finally reached a point where I could see it. I was rather exited. wink However when I looked through the 10mm EP with the X2 Barlow it looked much like Jupiter looked on my cheap 4.5" scope.. I figured I would have a better view then that, but I guess not. Really all I could see was a bright white sphere. I assume the color was from the sun rising quickly behind it. One thing I did notice however was it's fast movement through the EP. After about 15 seconds it would move totally out of view, and I could actualy see it moving! So it was not a total loss - I just figured I'd see more detail.
In any case it was a fun night. I got to see things that I have never been able to see before and I am already planning on objects to look for over the weekend should weather permit. Seems we've had lots of rain as of late; good for the thousands of toads all around, but not so much for me.
I was thinking about buying a 3X barlow and perhaps stacking it with the 2x for better views of Venus and what not. But I'm not quite sure it will help all that much. I do want to get some more powerful EP's also. But I'll see what this weekend brings.
Posted 07/08/2006 06:47AM #1
Good stuff! I would pass on the 3x Barlow. About the only thing of interest to see on Venus is its phases. There are a couple of other things: near its inferior conjunction (when it lies between us and the Sun), its crescent can occasionally be seen to wrap entirely around the disc of the planet. Also, if your eyes are exceptionally sensitive to the far violet, there's some minimal cloud deck detail you can see. However, most people have essentially no sensitivity at that wavelength.
I would work on Jupiter. It and Mars are my favorite planets, showing a wealth of detail under the right conditions. Between the two, Jupiter is larger and easier to observe for a beginner. I usually want at least 200x to observe it.
Posted 07/08/2006 12:02PM #2
Michael
Jupiter rotates fairly rapidly, so observing over a period of several hours reveals different features, such as the movement of the GRS and transits. Festoons on the northern equitorial belt are of particular interest. Take advantage of Jupiter now because it is moving further away and will ultimately remove itself from view for several months.
I Yam What I Yam!
