james carter
North American Nebula NGC7000
Having a few problems with movement of my scope.
Started by JesterDev, 07/10/2006 02:00AM
Posted 07/10/2006 02:00AM Opening Post
So I've been out quite a bit with my telescope and I have having some issues with it's movement. First off and most annoying the counter weight hits the tripod quite often when looking at objects closer to the horizon, or just playing around. It's already scuffed it once. Maybe I'm just moving it wrong. Seems like I have to reajust the tripod quite often which is really getting on my nerves.
Is there perhaps a video laying around that shows the proper movement of a telescope? Seems I'm moving by hand more then anything.
Posted 07/10/2006 02:12AM #1
Hi Michael,
Could you mention the Make/Model of the mount please! I am sure there will be someone knowledgable enough to solve the issue.
Thank you, Ansu.
FluffyDuck observatory
Celestron 8N/CG5 NON GOTO
Canon 20D, Neximage,MX516
Losmandy G11 GOTO
Posted 07/10/2006 03:37AM #2
Michael;
I am assuming you are having problems with your Space Probe 130ST which is an 130mm F/5 Newtonian on an German Equatorial Mount (GEM)
It sounds like you haven't polar aligned the scope, probably the cause of your difficulties.
You have 3 axises, the Polar axis, the Right Ascention Axis and the Declintation axis. The Polar axis is the one that is designed to be fixed, the others have slo-motion controls.
The polar axis should be pointed at the north celestial pole which is about 0.8 degrees from the North Star, ie Polaris.
If you don't have the manual for your scope, you can download it from Orion's website, or at least you used to be able to...
