invention???
Started by bobblack, 11/11/2008 03:14PM
Posted 11/11/2008 03:14PM Opening Post
I'm wondering if anyone knows of a better way to move the guiding scope around to focus on a star for PHD rather than the 6 ring screws. If not, I think an invention would be in order.
When I try to image M31 it is really hard to get a bright enough star for PHD using the current way. Maybe I'm just way out in let field, bob
Posted 11/11/2008 03:36PM | Edited 11/11/2008 03:37PM #1
No, you're not out in left field. Other systems have been/used in the past, like "x - y" guidescope mounts that move a plate up and down/side to side via knobs. Don't know if anybody's makin' a rig like this at the moment, but it is for sure practical if done right. OTOH, if your guide camera is reasonably sensitive, you shouldn't have to do a lot of movin' around anyways.
Uncle Rod
Time on your hands?
Posted 11/11/2008 08:35PM #2
You can get a plate that moves your eyepiece in x or y axis. I've seen them I think on a Williams Optics scope--but I have no idea where it came from.
A second thought.....Use your planetarium program to locate a star for guiding. In some shots (like M81-82), there don't seem to be many. In others (like M33 I think) there are so many little stars, it is hard for the guider to keep track of which one it is using.
Posted 11/12/2008 02:02AM | Edited 11/12/2008 02:04AM #3
Robert,
They ain't cheap but here are a few, 2 by Tak. and 1 by Geoptik (apm). I was never fond of the 6 point system either so I ended up buying a used, no longer available Mizar alt-az guiding mount.
Bob
http://www.tetontelescope.com/product_info.php?cPath=47_14_88&products_id=395
http://www.buytelescopes.com/product.asp?t=19&pid=1587&m=35
http://www.buytelescopes.com/product.asp?t=19&pid=1585&m=35
Fujinon 10x70 FMT-SX binocs
Tak FS-78 ƒ/8.1 - 630mm fl.
Posted 12/06/2008 02:44PM #4
What guide camera are you using?
