Jay Messeroff
Lunar & Solar Transits
Is it worth converting my 12" DOB to GO TO?
Started by IRScanMan, 07/17/2007 01:19AM
Posted 07/17/2007 01:19AM Opening Post
Good day!
OK. By posing this question you probably can tell I'm a bit wet behind the ears.
I've had my 12" Deep Space Hunter DOB for a few years and dabbled off and on(much like the viewing conditions in southwest Washington). When I purchased the scope the kind folk at the shop did me a service by talking me out of the $4k goto model. Instead they recommended that I buy the DOB for $700 and LEARN the sky. My problem being is that my available time for viewing and good viewing don't match up as much as I'd like to. Frustration sets in blah blah blah....when I can find what I'm looking for. When I do find my target I have to hug this big ole tube to keep it aligned.
I have seen very few options available to computerize/GOTO my 12" DOB without breaking the bank. If anyone has info on this conversion that can be performed by a novice I would most appreciate the flyer. If your opinion is that I'm wasting my time please let me know.
IRScanMan
Posted 07/17/2007 01:59AM #1
There are basically three levels:
Starhopping: This uses no electronic assistance. Get yourself a good star chart, a Telrad, and maybe a good finder scope. This is what you are using now.
Digital Setting Circles: This uses an encoder on your azimuth and altitude bearings that connect to a handheld computer (which, in turn can be connected to a laptop iif you really wnat to do so, but it is not necessary). You initialize the system by pointing the scope at a star (or two) and telling the system where it is pointing. From that point on, you select a target, and the handheld computer uses led signals (generally numbers of degrees and arrows for direction) to tell you where to push your telescope. WHen you hit "0, 0" on the led indicators, you are on the target. This is not a goto system (see next). It costs anywhere from $300 to I don't know--maybe $500 dollars.
GOTO systems: These have Digital Setting Circles connected to a set of motors. You initialize the system about the same as a Digital Setting Circle system by pointing and identifying one or two stars. THen you tell it where you want to go, and press a button--and it goes there. These are substantially more expensive. They are also very rare (but not unheard of) on Dobs.
A very good compromise for somebody who does not want to delay using his or her scope until he or she has learned the sky is to take the middle route--the Digital Setting Circles.
Hope this helps.
Posted 07/17/2007 06:57PM | Edited 07/17/2007 06:58PM #2
Herb Barnett said:
Good day!
IRScanMan
Herb, why not sell the dob here on Astromart and go for something like: http://tinyurl.com/2opy8u
It would be close to the same amount of money you have invested. It'd be a tiny bit smaller/lighter and have push-to capability. A number of club users in my area have these and they are quite nice.
If not, you can invest ~$500 in something like http://www.skyeng.com/ and get virtually the same thing.
Posted 07/26/2007 11:20AM #3
Thanks Gents for the advice and tutorial.
I've decided to take what is behind door number three Monty!
Nothing! yet.
I'm attending the Oregon Star Party in a few weeks (weather/forest fire permitting). I plan to muddle through this event with the current config and soak in what I see around me. Better yet, I will be hawking views through as many varieties of scopes as possible. This in conjunction with probing the owners for details will hopefully make the decision a little clearer.
Options:
a. keep the 12" Dob only in current config. >sad
b. keep the 12" Dob & add digital setting circles hardware. :S
c. chuck(sell) the dob and purchase a used 8"-10" Goto system w/ Equatorial mount. wink
d. apply for new credit card and buy $7k GoTo GPS scope. shocked
e. take a second mortgage out and purchase Takahashi scope. 8O
Thanks again!
Posted 08/11/2007 03:08AM #4
I agree with Jenna - buy a decent used 9.25 to 12" SCT by Celestron or Meade. $1.5K to $2.5K will do nicely. However, KEEP THE DOB. You won't sell it for a whole lot anyway. I started with the 12" DSH then bought a gently used 11" Celstron GPS SCT. When I get home tired from work but want a quick astro fix before hitting the rack, I pull the dob out of the garage (it's on a garden cart), let it cool down while I have dinner, and observe for an hour or two. On "planetarium skies" weekends, when time is no object, I use the SCT for four or five hours and do some astrophotography. Even then, I often pull out the dob, too, so I can share the heavenly wonders with more neighbors. (Bonus: sharing with neighbors educated them and now they automatically turn off their exterior lights when they see a scope in my driveway or on the lawn - how very nice!)
George
