lowest mag for great red spot
Started by cysmarc, 05/24/2006 12:00AM
Posted 05/24/2006 12:00AM Opening Post
Hi,
Just for fun! What was the lowest power in which you saw the grs in a refractor less than 105mm. Apo or Achro.
I saw it at 90x clearly with atmospheric turbulance. I will try at 75x tonight.
Clear skies
Posted 05/30/2006 04:57PM #1
Hi,
Clear skies
Hi:
Since reading this I was interested in this so last night I thought I would see how low I could go. The scope was not quite a refractor and at 12.5 inches a bit larger than 105mm but none the less....
Seeing was good but not perfect, obverving over some trees + smoke from neighbors BBQ... Scope was well cooled (2 hours with the fan before first observation.) Focal length 1288mm.
Here is how it went:
75X: GRS very clear (Paracorr with 20mm TV Plossl)
59X: GRS quite obvious (Paracorr with 25mm Ortho)
52x: GRS definitely there to be seen. (No Paracorr with 25mm Ortho)
I tried lower magnfications with no luck. At 52x I am pushing things, the exit pupil is up at 6mm and when I went to lower powers=larger exit pupils the astigmatism of my eye really kicked in and I could not get a clean focus on a target as bright as Jupiter.
