VDB 142 Elephant Trunk HOO
Need Help about size and Focal Length.
Started by jimw3470, 12/04/2006 08:01PM
Posted 12/04/2006 08:01PM Opening Post
I accidentally posted this in the wrong place, hope this fixes that, I have a C8 SCT with a focal length of 2000, my 7mm EP is too powerfull for it, moon is OK but overall a 12mm is about as strong as I can enjoy a view with. I figure at 12mm the magnafication is at 166. I want to move up so I thought I might sell it and buy a 10inch newt based on price and so on but in looking I noticed that the FL on this is about 1000, which is half of my C8 yet it's a bigge scope. Now I'm confused. I think my 7mm will work better in the 10 inch but magn. will only be 142x which is less than a 12mm in my C8. It sounds like a C8 will be better than a 10" newt for view?? Meade makes a 75LDX 10' that I thought may be better than my C8 but after reading things I'm not sure I would really be moving up? What am I missing? ...Jim
Posted 12/04/2006 11:58PM #1
Jim:
I am going to forego the part about how high magnification is often overrated. I am sure other A-marters will take care of that.
To directly address your question, I had a similar experiences with my C8 and a 5mm Plosll until I realized a number of things:
- the C8 was not well collimated and thus performed horribly at high mag
- atmospheric conditions make a big difference in what you can reasonably see above 150x. Where I live (sea level next to SF Bay), the atmosphere is often turbulent. At 5000 ft in Shingletown a year ago, I thought I had died and gone to heaven, literally.
- the 5 mm Plossl was not a good match for the scope but my 6 mm Radian is. The FOV in the Plossl was just two small. for better results however, I recommend an 8 mm Radian. 250x is just easier to handle for this scope under above average conditions. Along those lines, a 8-24 Zoom is quite a good match for this scope giving you a usable range of magnification.
Don't give up. With proper collimation, good seeing and carefully selected eyepieces, C8 can go above 300x.
Rey
Posted 12/05/2006 03:50AM #2
Thanks to all who replied and helped. I really like the C8 Powerstar I have it is very easy to use and set up, I think it souds like if I move up a larger SCT may suit me better, I just need to save a little more for that. When I use my 7MM Nagler things just look so faint and dark, the 9mm Nagler looks noticably better, so I just assumed that it was at its limit at 9mm. It may need collimnation but I don't know how to do that. Overall things seem to line up pretty good when I look through them. Thanks again to all who replied and don't be shy feel free to share your thoughts with me, Jim
