October Messiers
Started by davebudlong, 10/02/2005 05:00AM
Posted 10/02/2005 05:00AM | Edited 10/02/2005 05:52AM Opening Post
Got a Real short list this month, only 7 objects, that however is not the story of this months chase. We get to look at the easiest to find Messier Object in the sky and conversely what I think is the hardest to find Messier in the sky, as well as a really neat Galaxy in Cetus. So here it is this months tricks and treats.
M29 an Open Cluster in Cygnus, best at very low power and easy to find in Bino's.
M103 A pretty nice Open Cluster in Cassiopeia, also easy enough to find in Bino's.
M76 Here it is the hardest one of the entire list in my opinion, a real tough object to find, I never found it until I got my 8 inch scope. Thats not to say it can't be done, but I would not let yourself get frustrated if you cannot find it in anything less that a 4.5 inch Newtonian, or 90mm Refractor. If any of you do find it for the first time in a scope smaller than that I would love to hear about it though.
M74 It is a Galaxy in Pisces, it is sort of a fickle object you can find it in Bino's but it does not look like much, however it took the 8" dob to see anything more and even that was not much, but it is a great dark site object.
M34 An Open Cluster in Perseus, another great object for Bino's.
M45 The biggest gimme on the list, The Pleiades, now here is a great object to put on your Messier Bino list, if you have Bino's go out and look at it with them, then start your Bino log. Now that we have started that log too, you are on your way to completing your second Astronomical League observing program, go ahead and find someone to pat you on the back, you deserve it.
M77 Finally we get to go after that cool little Galaxy in Cetus I was talking about. It is very bright and after you find it in the scope you should be able to find it in Bino's. Some of you might be able to find it with Bino's without a scope at all.
Don't forget that Mars is going to be great this month, better towards the end of the month but really nice. Good luck to everybody, and most importantly Clear Skies.
Real men play Golf
Posted 10/02/2005 01:24PM #1
Thanks.That's really helpful.
Posted 10/04/2005 01:56PM #2
Dave,
This is going to be about the toughest list, until we get to all the galaxies next Spring.
I could not find M74 and M77 last year, hopefully I'll be a little better at starhopping and observing this year. M76 I never tried for. I've got the 90mm refractor and 4.5" reflector you called for in your email, and will give M76 a try.
The skies have been clear but pretty poor here lately with haze and bad seeing.
Thanks for the monthly Messier lists.
8" Zhumell Dob
90mm f11 achro refractor
Posted 10/05/2005 02:50AM #3
Dave,
I count 8 objects. Don't forget about M15, a real nice globular cluster in Pegasus! Even a small scope will show some stars.
Posted 10/05/2005 06:32AM | Edited 10/05/2005 06:33AM #4
When you say "M29", I think you meant M39. Both are visible now, but your description fits big loose M39 much better than small, compact M29.
Posted 10/05/2005 07:53AM #5
M76 was easier than I thought on my 80mm Megrez II: My log from 8/30/05 from my mag 5.0 light polluted skies:
M76 - very small glow @ 29x; and at 62x small moderately faint rectangular glow; a little more conspicuous with ultrablock filter (more 3D like and see 2 "areas" of glow)
Of course, that was after I found it easily a few days ago with my 8inch dob...
