Re: lumicon deep sky rear cell
Started by IGastaldo, 03/02/2006 04:25AM
Posted 03/02/2006 04:25AM | Edited 03/02/2006 04:26AM Opening Post
Don, there's no difference in what they will do. The main difference is in the way they would mount to your scope/eyepieces...
The rear cell model will mount in the visual-back of your scope, then you would screw the SCT diagonal into it, and then you would use all the eyepieces you'd like without having to worry about screwing/unscrewing the filter from each one of them. (mostly for comfort purpose)
The 1.25" model, as it's name says, is meant to be screwed into the 1.25" eyepieces, but if you decide to use more than one eyepiece, then you would have to unscrew it, and screw it into the other eyepiece... getting to be a hassle if you decide to switch multiple eyepieces. (not to mention risking to drop it if you are not careful)
Hope this helps,
Clear skies! 8)
Posted 03/02/2006 01:43PM #1
exactly what i was looking for ....thanks
