Re: Seeing some deltails in galaxies?
Started by davebudlong, 03/02/2006 05:20PM
Posted 03/02/2006 05:20PM Opening Post
I can't speak to the properties of your scope in specific but, I have an 8" Dob and from relatively dark sites I have seen the spiral structure of M51, it will blow you away if you get anything like I have seen. As mentioned M104 the Sombrero is really cool from even halfway dark site. M81 and M82 both give a nice contrast and because you can bounce from one to the other quickly or even in the same FOV you will notice some of the shape and structure of both.
Real men play Golf
Posted 03/02/2006 11:39PM | Edited 03/02/2006 11:40PM #1
Dave budlong said:
I can't speak to the properties of your scope in specific but, I have an 8" Dob and from relatively dark sites I have seen the spiral structure of M51.....
I've seen the same things Dave mentioned with same size scope.This was under an approximate mag 5.7 to 6.0 sky. As others have mentioned dark skies are very important. Observing skills come into play also. More experienced observers often see things totally missed by the less skilled.
But bigger is still better.
Larry
