sct ballance problem
Started by barndylady, 12/08/2006 04:08AM
Posted 12/08/2006 04:08AM Opening Post
hi i have a 8"SCT after adding several heavy componets to the rear of the scope it is very bottom heavy, i need to add weight to the front to ballance it out some any sigestions?
Posted 12/08/2006 06:33PM | Edited 12/08/2006 06:39PM #1
Go to a tire store and ask if you can buy some stick on weights for aluminum wheels. the weights usually come in strips with lines molded into them so that they can be cut to a specific size for a specific weight. This would be a permanent solution, I am not sure if you are looking for something that is easily removable.
I don't know if they make a product for this porpouse, but if so maybe someone else has seen it?
It is what it is...
Posted 12/08/2006 07:12PM | Edited 12/08/2006 07:13PM #2
Check here..., they have a good selection of weight balance kits...
http://www.scopestuff.com/ss_baln1.htm
I also use a metal dew shield, which helps a lot when you have a back-heavy scope... 8)
