I'm thinking about how to get premium eyepieces without breaking the bank and wondered what would be sacrificed by just buying the Ethos 21mm and using powermates (2X & 5X) to give me other focal lenghts, (I think 10.5 & 4.2). I've read contrast may be affected but are there signicant disadvantages with these barlowed focal lengths above as opposed to using say the closest in the Ethos range of 6mm/10mm eyepieces?
Using TV powermates on Ethos 21mm
Started by timstruth, 09/27/2009 03:12PM
Posted 09/27/2009 03:12PM
Opening Post
Posted 09/27/2009 05:28PM
#1
Hi Tim.
The Powermates perform very well, but they are long and heavy, and might give you balance problems. If you're changing back and forth a lot and having to readjust your balance (refractor?), that could be quite a distraction. Convenience should be a consideration. I have a definite bias though, for using individual eyepieces, without barlows. I'm in good company...Al Nagler expressed the same sentiment in his presentation at PATS yesterday.
If I was trying to assemble a small set of premium eyepieces right now, I'd check out the Naglers right here in the classifieds. Prices are down lately, and you could put together a good set of Naglers for the price of a new 21mm Ethos. A 22mm T4, 12mm T4, and 7mm T6, for example. Or maybe you can sneak in a used 8mm Ethos at the high end. (I think that's where the Ethos has the biggest advantage.)
There's my 2 cents. Spend them well.
Have fun, whatever you do.
Linton
Linton
Funding Member
