Why the price difference?
Started by gyrocopter24, 10/06/2010 05:48PM
Posted 10/06/2010 05:48PM | Edited 10/06/2010 06:10PM Opening Post
Why is there such a differences in prices between 1.25 and 2" eyepieces? Meade 2" is roughly 50-$100 difference in the use market and similar price from the new vendors. TV Powermate 2x 1.25 used is about $120, compared to $200+ for a 2"
What is a compression ring? is that like an adapter for a 1.25? on a 2"
Thanks to everyone
-Terry
Posted 10/06/2010 06:49PM #1
Going from 1.25 to 2 is a 62.5% increase in diameter, but it's a 256% increase in surface area!
Probably harder to make defect free stuff that's larger too.
Essentially, it allows you to capture and hold your eyepiece into your diagonal, or powermate, or what evere w/o ever having a set-screw contact the eye-piece barrel which could potentially mar the eyepiece barrel. Think of it as a ring clamp that holds your EP in place all the way around it's barrel instead of single point of contact like with a traditional set-screw.
