james carter
North American Nebula NGC7000
15 x 70 bino versus 8 inch dob
Started by gibson57guy, 09/03/2002 03:37PM
Posted 09/03/2002 03:37PM Opening Post
Hi, I was observing the Andromeda galaxy the other night. I initially located it with my 15 X 70 bino's and it was beautiful. I then located it with my 8" dob but it was somehow smaller meaning that the bino's were showing a lot more of the outside edges than the dob was...
1. is this a case of two eyes are better than one?
2. is something wrong with my dob?
3. is this because of the wider field of the bino's?
Any help would be appreciated.
Thanks
Mark V
Posted 09/03/2002 04:03PM #1
IF all is well with your dob, then in addition to two eyes are better than one, I'd be thinking it's probably because of the larger exit pupil provided by the binoculars. I have 15x70's, exit pupil is 4.6mm. To get a 4.6mm exit pupil out of my F8 scope I'd have to use a 36mm eyepiece. I could use a 40mm. To get the same with my F10 scope, I'd have to go to a 46mm eyepiece. The best I could do would be my 40mm = 4mm exit pupil. edz
Posted 09/04/2002 04:57PM #2
You lucky guy. A pair of 15 X 70s is high on my want list. There are a great many times that the binoculars will outperform even big scopes. Many things are just better such as M33 and M100 and of course clusters like M8 were made for binoculars. There is nothing wrong with your DOB, just use it for really deep space and planets. Binoculars rule! I have a 5 inch Mak and a lot of times my binoculars (a cheap pair of 10X40s) are more fun.
