Since my last posting under this thread I can boast the sighting of only 5 objects - SSO's (Shallow Sky Objects) rather than DSO's: The sun, the moon, Vega, Arcturus and Altair, all viewed with the naked eye. When I arrived at my vacation site (64 deg. north) 1st of July I couldn't see any star even at midnight, but from the 10th of July the brightest stars could be spotted.
I did an interesting experiment a few days ago, which can be used as an illustration of the importance of a dark sky background. What is needed for the experiment is a polarisation filter (a pair of good polarising sunglasses works ok), the sun must be up and there must be some clouds present on a clear sky background.
In the zone near 90 degrees from the sun the blue skylight is strongly polarised, while the light reflected from the clouds is not. By turning the polarising filter it is therefore possible to adjust the darkness of the blue background, while the clouds remain equally bright. I don't know exactly how much darker the sky becomes when the filter is held the optimum (darkest) way, but I would guess about 5 - 10 times, say two magnitudes surface brightness.
The interesting point for the deep-sky observer is how this affects the visibility of faint cloud patches. Some clouds were completely invisible with the filter in the position letting the polarised light through. Turning the filter 90 degrees showed the clouds easily, in many cases with intricate detail. Generally the view of all thin clouds improved dramatically by blocking the polarised light.
This demonstrates the advantage of observing DSO's from a dark site compared to a location with light pollution. The difference between a 4th and a 6th magnitude sky is tremendous regardless of aperture used. Notice that the surface brightness of the clouds is the same regardless of the orientation of the filter. Unfortunately a polarisation filter can not be used to block out light pollution.
Seeing is believing. I recommend all of you to try this once.
Inge S
Inge S
