book on double stars
Started by timwether, 07/19/2008 10:51PM
Posted 07/19/2008 10:51PM Opening Post
Hi everyone,
hope this is the right forum to ask this. Does anyone know of a book they could recommend on double stars? What I'm after is a book that lists the doubles in each constellation with their magnitudes and separations? Lots of books contain bits of this info but I've never seen one that had it all?
all the best
Tim
Posted 07/19/2008 11:23PM #1
tim wetherell said:
Hi everyone,
all the best
Tim
Online will have closer to it all.
Two book format are Burnhams (frequently available in the classifieds here) and Double Stars for Small Telescopes by Sissy Hass.
Posted 07/19/2008 11:31PM #2
tim wetherell said:Does anyone know of a book they could recommend on double stars?. . . Lots of books contain bits of this info but I've never seen one that had it all?
I have made good use of "Double Stars for Small Telescopes" by Sissy Haas (Sky Publishing Corp.). It covers all celestial constellations, in your part of the world as well as up here in the northern hemisphere. But -- as the title implies -- if you're looking for doubles with sub-arcsecond separations or primaries dimmer than about magnitude 8, this book won't accommodate you.
By the way, there is an Astromart forum for double stars, which may be a better place for your inquiry.
Posted 07/19/2008 11:51PM #3
Hi Tim
Have you seen the SAC double star data base? This isn't a book but it sure has a lot of info including a 39 page list of doubles sorted by constellation. It is available in several formats including Excel so you can sort and filter as you see fit. I printed a copy and stuck it in plastic liners for field use. With a decent star atlas, it's all I use
http://www.saguaroastro.org/content/downloads.htm
clear skies,
dan
Posted 07/20/2008 06:54AM #4
thanks for some great links everyone. grin
all the best
Tim
Posted 07/20/2008 01:44PM #5
tim wetherell said:
Hi everyone,
all the best
Tim
In addition to books, do you know about this:
http://www.jdso.org/
A wonderful project that I had a hand in birthing, at least. ;-)
Uncle Rod
Time on your hands?
Posted 07/20/2008 04:28PM #6
In addition to the sources already mentioned, _The Night Sky Observer's Guide_ has lists of binary stars for each constellation.
Dave Mitsky
Posted 07/21/2008 05:16AM #7
Tim,
You should also be aware of the double star forum under this site. There you will learn many interesting things from dedicated double star observers.
Inge S
Posted 07/22/2008 02:20AM #8
"A Field Guide to Double Star Observing" by Joe DalSanto is another good source.
