For this fateful event, my 4-inch TV-102 Light Cup and I took a long trek to a 2800m high mountain top (9333 evel.) Due to the series of unfortunate events, we had to settle for around
2000m (6666 ft evel.) :-(. More on this site in the report, Light Cup High Sierra ;-).
Now I've tried to bag Comet 9/Tempel 1 from my NELM 3.5 backyard sky and it was a hopeless quest. The NELM is a prestined magnitude 7.2, not bad ;-). After setting up, I started to
locate the comet around 10:05pm (Jul 4th 05:05 UT). Using my 40mm Pentax XL (22x), I suspect the comet in the area indicated by my The Sky chart. Switching to the 20mm TV Plossl (44x),
the comet could be readily seen as small very dim smudge. Upping to my Galaxy Grabber eyepiece, 12mm Radian (73x), gave the best view of the comet. The comet was situated SW of the mag 12 star GSC 5546-1397 which forms a triangle with the star GSC 5546-882 and the brightest of the triangle, GSC 5546-1273. The 8mm Radian (110x) was used often as well especially with averted vision, exposing a stellar core at times. The seeing wasn't particularly good. I'd say the comet was very dim, more like magnitude 10-11 galaxy with a core.
About 10:20pm, I side tracked to M51 to try to catch the new supernova, SN2005c, but alas, while the 13.3 magnitude foreground star was easily seen, the SN was nowhere in sight :-(.
Now the press and predictions were saying that the result of the impact could have brighten the comet to magnitude 6! I was always skeptical of this but figure magnitude 8 might be more reasonable.
At 10:45pm, I quickly switched back to the comet and settled in at 73x. Lo and behold, at the appointed time of 10:52pm (05:52 UT), nothing happened! I stayed at it until 11:20pm (thank to the Radian comfy eye relief). Zero, zip, nada, no
flashes, no brightening. I noted the stellar core blinked in and out perhaps due to the seeing.
I stayed at it until 11:50pm and decided to throw in the towel :-( and move on to observe the more profitable ;-) Palomar globulars. My Light Cup speculated on the cause as one of the following:
- it was a miss ;-) (just saw on the net that it did hit!)
http://skyandtelescope.com/news/article_1541_1.asp
- the impact occurred at much later time
- 4-inch was alas too small of an aperture :-(
- it hit the target alright but without much hoopla ;-)
Anyone saw a huge flash or brightening? Magnitude 6 in brightness ;-)?
Well not all is lost ;-). My Light Cup did manage to show me that the comet did move from the first noted position to south of the star GSC 5546-1397 by 11:50pm ;-).
Ron B[ee]
Ron B[ee]
