Wizard Nebula
Deep sky objects observed 24th of November 05
Started by Inge_S, 11/25/2005 07:20AM
Posted 11/25/2005 07:20AM | Edited 11/25/2005 07:22AM Opening Post
Yesterday night the sky cleared up in spite of bad weather forecasts, and I used the opportunity to make a combined DSO and double star session. At this time of the year, observing conditions very seldom are good enough for observing, therefore I started the session observing some Cetus objects.
The planetary, NGC246, was one of the most fun objects I ever observed. There was some distrubing light from Stavanger, therefore the nearby guide stars could hardly be seen with the naked eye. However, I noticed a group of faint stars that seemed to be embedded in some nebulosity. Applying the O-III filter the nebula popped out, almost like a miracle. I found it large and round with hint of some structure. A part of the edge was very sharply defined. Very good object using the O-III.
I also checked the region near M77, to see if I could spot some of the other galaxies in the group. M77 itself appears extremely bright, but quite small. I hoped to spot four more galaxies, but could make out only two, NGC1087 and 1090. In this part of the sky, the Stavanger light was pretty annoying.
I spent quite some time with M33. Its spiral structure is pretty obvious with the 12.5-inch, particularly the north-western arm with the emission region, NGC604 is prominent. Also NGC592 was very clear, while I found NGC588 and 595 (all emission regions of the Pinwheel galaxy listed with separate NGC numbers) more difficult. I switched between the 24mm Panoptic (63x) and the 9mm Nagler (167x). M33 demonstrates that I need an eyepiece giving a power in between, probably a 13mm Nagler.
The great Andromeda galaxy was a marvellous sight this evening. Two distinct absorbing lanes running parallel on the western side of the galaxy were obvious, and the NGC206 patch was bright.
I also reviewed the companion galaxies, including NGC185 and NGC147. With my aperture none of them are really difficult. It is very interesting to move between 147, 185 and the smaller, more distant NGC278. It is almost hard to believe that they all belong to the same class of objects.
I observed several galaxies, clusters and nebulae in addition to those already mentioned. At 167x it was possible to see hints of the filamentary structure of the Crab nebula. The visual impression in the eyepiece reminds me of the photo in Kepple&Sanner, Vol.1 p.385.
I scrutinised NGC1931 (Auriga) at 375x, to get a really good look at the stars involved. Actually this nebula contains a triple where the stars (not exactly the same magnitude) form an almost equilateral triangle.
I was not able to capture the spiral structure of NGC2403 in Camelopardalis. Somehow I find the foreground stars to be a bit disturbing. Maybe a 13mm Nagler will help.
Inge S
Posted 11/25/2005 01:53PM #1
Hi Inge --
Your observing report is interesting and useful. Thanks for sharing.
Bob Polcyn
