NGC7000
Started by kulginov, 09/29/2005 11:53AM
Posted 09/29/2005 11:53AM Opening Post
Yesterday evening was cloudy, but the air was so transparent that the view from my balcony looked like a painting by an old Flemish master. Before I went to bed, I checked the skies - they were clear with some clouds near the horizon. I rushed to the back yard with my ST80.
I looked at the NA nebula with my new Panoptic 24mm and the Baader UHC filter. The view was extraordinary - after a couple of minutes at the eyepiece I easily saw the whole 'continent', with a lot of mottling in the Canada part. The light pollution disturbed my dark adaptation, but not the view - thanks to the air transparency.
I think this is the best setup to view this nebula. I've never had a better view, even with 8" from a dark site. The UHC filter is optimised for 5mm exit pupil, and a higher aperture would have decreased the exit pupil and the field of view. The wide field of Panoptic had put that final touch on the aesthetic experience.
Dmitri
Posted 09/29/2005 10:18PM #1
Dmitri
Excellent report, thank you!
Where did you find the technical data on the Baader UHC filter?
Anthony
Posted 09/30/2005 05:12PM #2
Dmitri,
I also had very transparent skies on Wednesday evening, and looked at the North American nebula using my 4-1/2" f4 reflector at 18x. I could see 'parts' of the nebula, but the vast numbers of tiny background stars actually made the continent shape difficult to see!
I could easily see the round open cluster NGC 6996 within the "Canada" area of the nebula.
8" Zhumell Dob
90mm f11 achro refractor
Posted 10/03/2005 06:07AM | Edited 10/03/2005 06:08AM #3
I have never seen NGC7000 with anything less than 8 inches of aperture. In most text I have read about this nebula it is referred to as either a binocular object or an object for a big scope. But the optimum is perhaps an aperture in the 3 - 6-inch range.
I often observe this nebula together with the other nebulous patches west and south of it with my 12.5-inch. The region around the "Gulf of Mexico" is quite impressive with an O-III filter. However, lack of contrast makes it difficult to detect features in the northern part.
Inge S
