Observation of small DSO's
Started by Inge_S, 12/17/2004 11:09AM
Posted 12/17/2004 11:09AM Opening Post
I consider myself an experienced observer, although a 10 year period here in Norway is needed to make up for a couple of months in the Arizona desert. I feel relatively comfortable observing low power DSO's as well as double stars and planets at high power. However, I sometimes encounter problems when I want to use high magnification to make out detail in small planetary nebulae and galaxies. The main problem is focus. I have never owned a set of perfectly parfocal eyepieces (not even my new TeleVue line satisfies that criterion), and therefore I have to re-focus when I increase the magnification. Focusing on a planet or a double star of decent brightness is no problem, but to get a diffuse object perfectly focused can be a bit of a challenge. If there is a bright star in the same field of view, I can use this to get perfect focus. However, this is not always the case.
I also find that I have to make a slight change of focus if I apply my O-III filter. The filter steals much of the light from the field stars, making focusing even more difficult.
Any good suggestions?
Inge S
Posted 12/17/2004 01:56PM | Edited 12/17/2004 02:37PM #1
Focusing lever, easy to make, works miracles. I'll send a picture from home. The prototype made by Florian Boyd can be seen here (together with him?):
http://tinypic.com/bydd1
http://tinypic.com/bydcp
It's too long for my taste, and I've added a couple of springs to the construction.
Dmitri
Posted 12/20/2004 02:47PM #2
Since visual observation of extremely subtle features like the M87 jet is possible, I would also expect that some detail should be possible to make out in some of the planetaries. What can be seen in NGC6543(Cat's eye) or 7662 in Andromeda? I'm highly interested in observation reports of the brighter planetary nebulae with telescopes in the aperture range 10 - 15 inches.
Inge S
Posted 12/21/2004 02:58AM #3
Hi Inge,
I have used a focusing mask for this purpose. Mine is the very simple type with two diametrically opposite holes in a piece of cardboard, which is placed at the top of the telescope tube. However, I recently found a very interesting variation of the focusing mask which has two circular holes and a triangular hole. The use of the third triangular hole is very cunning ... it gives instant indication on which side of focus you are!!! As you move through focus the triangle flicks to the ofher side of the view. For your 12½" the circular holes should be 5" in diameter and diametrically opposite one another. The equilateral triangle is then cut on a radius at right angles to this diameter, and with one corner pointing towards the centre. It is well described on:
http://cometman.com/Mask.html
Making one is on my "to do" list.
Anthony
