Iris Nebula
The benefits of aperture
Started by wisemanrs, 09/23/2008 01:45AM
Posted 09/23/2008 01:45AM Opening Post
Everyone,
I have observed for four years using a 90mm refractor, and with some success. All 100 Messier objects and many other NGC clusters and planetary nebulae.
Well, I recently purchased an 8" reflector, and I wanted to report a few observations.
The best: globular clusters. I reported in the "Under 124mm" forum recently about a good night when I was able to resolve M13, M92 but not M3 globulars with the 90mm. It took four years of experience and good clarity and seeing to do this. With the 8", any night, whatever seeing, I can not just resolve the globulars, I can blow them apart. At 320x, I feel I can lay down in and grovel around among all the stars! Stupendous.
Excellent: planetary nebulae. Many have high surface brightness, of course, but are tiny. 320x makes them obvious greenish disks. M27 is huge, M57 is a beautiful round cheerio.
Maybe good, galaxies. I haven't seen enough at this time of year. M31 is huge, M32 is bright and with M110 appear far away from the big galaxy. M33 and M110 not so good, but they were low and the clarity was not that good.
Jupiter is excellent, but I saw the planets pretty well with the 90mm.
By the way, I still never did see the 'color' with my 90mm f11 achro that all the Apo guys worry about. The colors in the 8" seem the same.
More observations in a later post, thanks for reading this,
Rick
8" Zhumell Dob
90mm f11 achro refractor
Posted 09/23/2008 02:38AM #1
About a year and a half ago I got and 11" sct. Prior to that I had a 8" sct. In the three years I had that scope I was able to observe around 450 galaxies. I think you'll enjoy your new 8".
Andreas
DSOs observed:
NGCs 2005, ICs 103, Other 70, Palomar GCs 6, Abell PNs 12, Herschel 400: 316.
Equipment
Celestron CPC 1100, Lunt 60mm Ha Solar Scope
Posted 09/23/2008 03:26AM | Edited 09/23/2008 03:26AM #2
"By the way, I still never did see the 'color' with my 90mm f11 achro that all the Apo guys worry about."
A 90mm f/11 is too small and too slow to have a lot of secondary color, and it would only show on the brighter objects.
The advantage to a 90mm apochromat is versatility, providing low power, wide field views and arguably the best high power views for the aperture. It is also great for daytime viewing. The little 80mm f/6.3 achromat I had here for a few weeks showed secondary color only on the brightest celestial objects, but daytime viewing featured lots of annoying purplish fringing on high contrast borders.
I think you'll love your 8" telescope. There is a lot to see with 8" of aperture.
Clear skies, Alan
Posted 09/23/2008 06:54AM #3
Rick,
I strongly recommend that you get yourself an O-III or UHC filter to use with the 8-inch. This will add another dimension to your observing. Personally I recommend the O-III. This filter works wonders on the Veil nebula, and objects like the Rosette nebula and Crescent nebula (NGC6888 in Cygnus) are difficult to detect without the filter, but stand out clearly with considerable detail when a filter is applied.
But be careful! I didn't use the 8-inch for many years before I just had to upgrade to a 12.5-inch scope.....
Inge S
Posted 09/24/2008 01:34AM #4
Sorry to the guys in the "Under 124mm" forum. cwy
Rick
8" Zhumell Dob
Posted 09/24/2008 11:07PM #5
Rick
I think you need more aperture already.
Take a good long look at Classified #587094
Regards
John
