The Veil from an Urban Backyard
Started by jonisaacs, 11/19/2008 03:16AM
Posted 11/19/2008 03:16AM Opening Post
One of my observing goals for this year has been to see if I could see the Veil Nebula from my urban San Diego backyard. I live in a typical California city, lot of homes on 60x100 lots with apartment buildings and malls nearby, some green space here and there... the populaton density for my zip is about 6000per square mile.
On the best nights, I have been able to detect stars near overhead of magnitudes 4.6-4.8 but a normal good night is closer to 4 sometimes under. Nearer the horizon it dimishes drastically.
Saturday night we took the 10 inch/5 Dob out to a local park where there is noticeably less light pollution and gave the Veil a shot using an Orion O-III filter. I was able to detect the section surrounding 52 Cygni as well as the crescent section which was actually more distinct. I tried a variety of eyepieces, the view in the 24mm TV widefield showed it with the most contrast. This is about 60x and a 4mm exit pupil (with Paracorr.) I was quite pleased with this and it was sufficient to satisfy my goal of observing the Veil from San Diego.
Sunday night I decided to give it a go from my backyard. I setup my 12.5 inch F/4.06 so I would have the best view through the trees of the Veil. The moon wouldn't rise until past 8pm and the air was turbulent but transparent.
Anyway, again, I was able to spot the two brighter sections of the Veil with the crescent being the brighter, more easily seen. I was able to follow it and just enjoy the view.
Obviously this is a testament to the value of the O-III filter in seeing a specific nebulas, I am quite pleased in any event.
Later in the evening I spend some time observing Kemble's cascade and decided to see if I could find the nearby planetary NGC-1501, surface brightness 12.73, it's about 1.5 degrees due south... it popped right into view with the filter and was visible without a filter. Without the filter, higher magnifications helps, a 2mm exit pupil at about 170x was best.
Anyway, for us urbanites/suburbanites, DSOs are not necessarily limited to clusters and those super bright planetaries, some of the fainter stuff can be seen. Obviously the Veil from my backyard pales in comparison to the thrills it provides from a dark site but I was still a happy camper when the evening was finished.
Posted 11/19/2008 06:39AM #1
Jon,
Thanks for the report. You are indeed right that some diffuse nebulae can be observed under less than perfect conditions. I once observed the Veil from my driveway when a truck stopped 20 metres away with the headlights directly pointing at me. I still could see the brighter filaments of the nebula, but I quickly closed my eyes to save my night vision.
As a next challenge you may try to see the Crescent nebula (NGC6888) in Cygnus. It is much smaller and fainter than the Veil, but with the O-III filter you should have a chance of detecting it. There are also some not so frequently observed diffuse nebulae in the winter Milky Way (Perseus, Auriga, Monoceros). Most of them are, however, rather featureless, but nebulae like NGC1931 (on the route between M36 and M38) and NGC2261 (Hubble's variable nebula) are bright enough, and may be visible even without a filter.
Inge S
Posted 11/19/2008 02:43PM #2
Jon: My back yard very seldom reveals more than 3 stars in Ursa Minor, and on occasion a hint of the milky, mostly not though. But, yes NGC 1501 was a not too difficult target, as has been the veil from time to time (12") dob. The only time the NA nebula was seen was with my 20X100 binos, and only after carefully identifying key stars could I make out the east coast of Canada, the Gulf of Mexico and Baha. Right now I am having a difficult time in seeing DSOs in Triangulum. Not yet observed are NGCs 784, 925, 949, 1058 and IC 239. One of my guidelines is NGC 147. If That is visible, then other items are possible. Almost always 147 is elusive. Several other items are used in this fasion to determine whether it will be a good night from my back yard. What are your guideposts?
Jud
I Yam What I Yam!
