With the departure of foggy nights and incoming heat wave, the TV-102 Light Cup got out for a quick viewing last night from 11:30pm to 2:00am. With the moon still up, the LM was a horrible 4.9 in Cygnus (and darkened to mag 5.6 in Sgr after the moon has set). I've always been intrigued by DSO with name (and the Light Cup loves to give a new name); so we visited these open clusters.
NGC 6811 also known as "Hole in a Cluster" was easily found at 22x (40mm Pentax XL), very dim, roughly round group of stars, a good size. Would have easily missed without detail chart. Background still gray at 30x (30mm Ultima). The “hole” is now seen at 44x (20mm TV Plossl) with direct vision and is surrounded by a circle of stars. Averted vision brings many more stars in the hole. Lost impact at 73x (12mm Radian) with darker sky background but hole is
less seen with many more stars in the area of the “hole”. Counted about 30 stars, which are dim enough to look uniformly white. This is an interesting, must see cluster.
NGC 6819 also known as "Foxhead" was also easily napped at 22x, dim like NGC 6811 but seemed to have central brightness, much smaller and more condensed. Form a triangle with the star HD 186255 and HD 186307 at 30x. Looks like a small, loose GC, but compressed. At 73x, it’s impressive in that if I hadn’t known it’s an OC, I would
have though it was a GC. Appeared completely resolved at 110x, too many stars to count, guessing < 100 stars. Does anyone know how this OC got the name “Foxhead” ‘cause I reason seems to escape the Light Cup (we didn’t see any shape). Oh, I get it; the Light Cup muar have been looking down the wrong fox hole ;-).
Alas, NGC 6888 (the "Crescent Nebula") was nowhere to be seen even though I've located the star field precisely. Perhaps, this object can be seen with filter and on moonless night.
Believe it or not, I haven't seen the Coathanger (Cr 399) yet :-(. But the Light Cup did take me to NGC 6910, dubbed the "Mini-Coathanger". Located precisely with detail chart at 22x. I mistook the stars HD 229196, HD 194241 and HD 194279 to be the coat-hanger without the hook. At 73x, the coat-hanger shape is quite apparent with the coat-hanger being the stars HD 194241 through HD 194279 with a total of 8 stars. The hook is made up of stars GSC 3156:1857, GSC
3156:744 and GSC 3156:850. Best view. Still nice at 110x (8mm Radian). Since this OC also has the name "Wishbone", I also noted that the star HD 229196 together with the rest of the stars I noted did looked like a sort of "Y" shape wishbone!
Before packing it in, the TV-102 Light Cup did make a wish to NGC 6910 for an excellent weather after the full moon for a rematch with Pluto and the NGC 6118 arch nemesis ;-)
Ron B[ee]
Ron B[ee]
